It'll take 100 miles or so to bed in. So keep that in mind. As your management system will need to relearn your driving style and adjust a bit. So make sure you don't just give it beans but also don't just tootle around like a granny.I'll let you know my honest opinion when after its been sorted on Tuesday. Obviously it will take a few weeks to determine if the fuel consumption has changed in anyway.
I'll also try and get some info from the fella who is doing it for me.![]()
Thanks I'll check that outYour mate is right.
The 110's do go to about 140. And you will get either the same mpg or slightly better. Sounds like a bhp-orientated map that though you can get one to take it to about 120 and a lot more mpg than stock.
www.bvrautomotive.co.uk is our local VAG mappers and I think they have a calculator on their website if you want to take a look.
Cheers I wasn't aware of thatIt'll take 100 miles or so to bed in. So keep that in mind. As your management system will need to relearn your driving style and adjust a bit. So make sure you don't just give it beans but also don't just tootle around like a granny.
Well you have a point .never bothered. not sure if the savings on fuel will be better than costs of replacing the ecu unit/injectors/pump if you mess up things too much?
ECUs can be very temperamental. Best left to the experts. So many things can affect their parameters.
The trouble is there are not many experts out there when it comes to the electronic boxes vehicles seem to be filled with
Too many times vehicle techs have a replace everything attitude rather than an ability to interpret the fault codes and analyse the source of the fault
It's not quite that technical. I've had a few fast scoobies and evos and I'd get them remapped whilst driving around to give a real custom map. Every time I changed a part. It'd never be the ECU that would blow, itd be a turbo or bottom end lol
But you're safe with these fairly stock maps.
On vag 1.9 and 2.0TDI engines there's a limit people go before they say it's a race map and will make you sign somebody to say it's on your head.
Otherwise if you're not happy with it; most keep your actual map before they wipe it and can put it back on. Usually FOC too.
So, I have now got an update regarding the mapping of my Golf.I'll let you know my honest opinion when after its been sorted on Tuesday. Obviously it will take a few weeks to determine if the fuel consumption has changed in anyway.
That could have happened anyway? Your egr valve went. I assume it was plugged in to check errors so wouldn't have been an issue during the remap. Cars are just cars.So, I have now got an update regarding the mapping of my Golf.
I had the ECU re-mapped and the car performance increased quite noticeably. The running cost (fuel consumption) doesn't appear to have changed much, a touch slightly better but nothing significant.
But after a short period I started to have problems with the DPF (diesel particle filter) blocking quite quickly. This is a filter that is part of the exhaust system which basically cleans out the soot from the exhaust gas. The car is programmed to regenerate the filter, basically when the car gets to temperature the car's management system alters the fuel mixture and injects fuel in the exhaust so that the soot can be burned away at high temperature.
It turns out that my car had a faulty EGR valve (exhaust gas recirculating valve) which is also part of the exhaust system and is all linked in with the DPF and controlling emissions.
The car began to run terrible and I found I had to take it on a long run to clean out the DPF on a regular basis (at least once a week) to sort the problem. So after living with this for a month I decided enough was enough and got a friend of mine to see what he could do.
My options were:-
A. Replace both the EGR valve and the DPF (at a very high cost, in the thousands).
B. Have the car re-mapped again to omit the EGR valve & the DPF and modify the exhaust.
So a piece of advise, have the vehicle checked out first before you commit to performance modifications. Modern diesels, due to emission laws are a pain in the butt!
