- Aug 26, 2025
- 5
- 0
- 50,001
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Looking to replace current gas hob with an induction hob. Ignition cable for g
as hob runs to a fused spur which in turn runs to a 32 amp fuse. I think current cable is 2.5mm and runs behind tiles walls. Could a new induction hob be wired with this existing cable.
