E
eco-tech
I have a problem with a light tripping a rcd etc.
All the circuit tests out good.
No tripping when a bulb not in and voltage is correct when i put across L and N
When i place a bulb in the fitting it trips.
Any ideas chaps ?
RCD TRIP or MCB Trip
take fitting down and replace with pendant!! rule the fitting out!! or in
yeh done all that. I replaced with a pendant etc. It still trips the rcd.
The strip light in the other room is at fault tho as it wont strike up so do u think it could be due to this even if the switch is off blah blah.
Yeh i changed 3 lights for them nasty wire crapy grrrrrrrrrrr take ages to wire lights lol
all other lights work fine tho
Maybe a loose N do you think in a fitting ?
appears to me the pendant neutral is connected to a cpc
a n-e IR fault would cause additional symptoms
could be wrong of course
whats the wiring arrangement?
is it a low energy bulb ? ive had one go and trips the rcd but didnt let you reset it with bulb still in ! for the sake of 5 mins its worth testing all low energy bulbs in a table lamp.
Ok
Looked at the job today
What i have is a pendant that trips the rcd.
After looking into this i found a N that leads to nothing.
Looks like this N should be connected to a pendant after belling out etc.
My thoughts are this N is not connected to this pendant i found and the pendant then leads to a terminal j/box will this cause the other pendant to trip out.
I think the N must lead to a j/b from the light fitting and the loose N leads to d/board.
So my plan is to link this N to the pendant and things should work !
Any ideas chaps ?
Lighting tripping rcd
eco-tech,
pushrod,
