Currently reading:
polarity argument at work
Discuss polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
O
Olliew
What do use in emergency lighting brown permanent live black switch live or black permanent live brown switch live obviously grey neutral major arguments at work please help to settle
Like Lenny said, how is it wrong when all the manufactures use black as the permanent???
Personally I use black as perm, purely because I've been taught that way and everyone I work with uses that way.
Exactly, if the lighting system throughout uses perm live as black , so am I, you always been told look at manufacturers, it makes sence to keep the same.
This Dereck guy acts very srangely, perhaps he had a hard day I suppose.........
if you tried to play god with me on site derek, then id jack there and then.i couldnt and wouldnt work for someone who tried to enforce their opinion as right.
I have a rule, if i disagree with an opinion at work, i make my opinion known, and give my reasons. I listen to the other persons opinion. I then go away and try to find info to justify either my or their opinions, and if possible find regs to back it up.
Even if i then dont go back and tell the person who i was arguiing with that i was right, ive often learnt something.
If i went around not listening, then i wouldnt know as much as i do, and i wouldnt learn as much as i want to learn.
We go on about sleeving everything but, if that's the way to go, why are blacks (live) not sleeved in made up plug in roses (gregs) ? I always sleeve or mark, by the way.
The bottom line here is that the regs don't prescribe anything, so it's left up to us. Then see what happens....... So maybe we need a few MORE regs, or a few less?
In the meantime, I'll just keep using my eyes and brain to check what others have done. Oh, and keep the supply of sleeving in the van well stocked.
Basically I am like god on my sites I run. So my way or the highway. But I do take into account everyone is different
At least when you're working for someone like that you know where you stand, which is far better IMHO than someone who says "whatever you think" then moans afterwards.
Personally I work in this order:-
1) Follow convention on site.
if there isn't one
2)Follow the convention on acessories
if that doesn't apply
3) Whichever gets the sleeve becomes the switched line
If the job is mine or I'm running it then I follow 3) as a general rule for no other reason than personal preference. Whatever way it's done, to be honest there are more important things in life and work to get excited about. :)
as i have said before, this was never a problem before some d***head in a suit decided that the cable colours that had been used since the year dot should be changed to colours that have no logical reason or sense.
I generally use brown as live, black as switched, grey as neutral BUT when working with others always clarify what they are using as what, simple communication!
I don't agree with bad attitudes, putting people down and shouting and balling on jobs/sites does any good, it just leads to a bad working atmosphere and poor work!
At the end of the day you should be able to go to work get along with everyone, have a few laughs and go home!
A happy work place is a more productive work place!
last time i worked on site, this clever t*** decided it would be a good idea to cut into the insulation on my VDE cutters. he wasn't happy to find a dog turd in his toolbox.
Telectrix- think I can smell something bull**** right there. Nothing to do with the argument!
I thought the argument was finished, many opinions , main consensus was that keep consistent throughout or match manufacturers lighting systems, and regards you, I think it don’t mater, you still going to "rape" your pure lads on site
:6:, feel sorry for them. lol......
I think you are a very very good spark, otherwise I find it hard to understand how you achieved what you achieved (being a foreman on many sites). I bet you going to buy some beer for them lads on Friday, aren’t you?
I Have argued that Jare it all comes down to single ph 3 ph new old confused EU wiring
as for SWA Grey is to be used as neutral as recomended by ESC to prevent confusing things If they dont like "Confusing" things WTF did they agree to change to bring us inline with those EU members who cant wire anything right anyways
Surely, the point is if it sleeved, there is no problem what you use. As long as both ends are the same.
The problem occurs when there is no sleeving, and assumptions are made, and we know what assumption is - the mother of all **ck-ups.
The problem arises when you put the sleeved black in the L terminal and the brown in the A terminal on the emergency fittings, while someone has fed the permanent live into the sleeved black and taken the brown back from the switch.
Either that or when you use prewired connectors where the manufacturer has wired brown to L and black to A, but the installer insists on doing it the other way around.
Can anyone explain how they wire non-emergency fittings if they're using black as switched live? Do you take a 4 core to the fitting and terminate the brown so you can continue using sleeved black as switched live? Bear in mind the NICEIC recommend any unused cores should be earthed, does this mean brown is now earth in part of the installation?
I think I can see your problem.
You are looking for an argument.
Unfortunately you've chosen the wrong subject.
Other than you, no one cares enough about the subject to argue about it.
As long as the same colour is used at both ends of the cable, it doesn't matter which one it is.
Reply to polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
