Currently reading:
Socket Zs High
Discuss Socket Zs High in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
They are taken care of if you zero the meter before every use!!
If you don,t know how to use your meter, then don't blame the posts!!
and how do you know if i know how to use my meter or not?....look,...i think your a slippery little character you....i noticed how your posts have altered a bit here n there throughout this thread.....early on...you refered to earth-fault-loop-impedence as PSCC....then you accused me of getting confused with Zs and Ze...i think not fella......then it was just plain Z.....
you cannot absolutely guarantee that test leads will be nulled out succesfully first time every time moses....even just the crocs can give funny readings sometimes......and sometimes dodgy test leads will not manefest themselves until you start to manipulate them/move em around....such as you would to take readings...
i dont just assume owt mate.....if i even get even slightly suspect readings...the test leads and the interface is the first thing i check....before owt else....
Reply to Socket Zs High in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
