Discuss Sockets keep tripping in the UK Electrical Forum area at ElectriciansForums.net
But I still believe that had one been plugged into the socket which gave me the shock, that would have probably been a barrier to prevent the electric shock.
They are more likely to form a capillary pathway for moisture than to provide a barrier, and as I said in an earlier post, it's more than likely that you received the shock from the switch.
Yes I can understand how they can also be dangerous. But when I received the shock from the socket, no plastic plug protectors had either been purchased or used. The socket had nothing at all plugged into it.
When you plug in the covers they open the shutters which are there to prevent them being opened, I am also out.
Ok thank you for confirming that. I wasn't sure as some of the prongs on them are very short and just assumed they are safe to use. I only purchased them after the electric shock. I assume no safety shutters could have been opened on the socket that gave me the shock, as nothing at all was plugged in...
I will get the socket replaced asap.
Did you get this issue sorted?
Has the landlord had the socket replaced?
Reply to Sockets keep tripping in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
