Marti
289
298
138
Poole, Dorset
Business Name
Jigsaw Electrical Services
And the first filthy minded individual that answers "Vaseline" goes to the back of the class :)
About to buy a HOLE SAW set. One of those with the dinky QR arbor to push the disk out will do nicely. My, very serious, query is "what sizes are the most useful?"
20 and 25mm for grommets and conduit perhaps but down lighters seem to be every damm size!
Your thoughts ladies and gentlemen?
Around 75-76mm is the most common LED downlighter hole size in my experience,and a good 115mm or so is handy for drilling wood or pvc soffits for fan ducting.
for drilling in steer, get good quality hole saws, usually 20mm, 25mm and 32mm will be all you need. for downlights, a set of 6 with arbout, generally 32mm - 75mm sizes about £6.99 the set.
If I was you mate I would try and get Piles of them, you would certainly hold the monopoly on suppositories.
Get a good quality stepping drill that does 6mm to 32mm for all steel and plastic. Leaves a lovely smooth edge on steel and plastic. I tend to buy a plumbers set and an electricians set which covers me for most holes. But then dammit I still find I have to buy the odd sized hole saw.
  • Agree
Reactions: Rpa07
You started it Marti?
you shouldn't use Vaseline, it reacts and breaks the condoms, you should use a water based lubricant instead. you will then no longer have sore holes!
  • Informative
Reactions: paul291277
but pacing up and down Lime Street are ----- soles.
There's got to be a link to 'saw tips' here somewhere. Got any 'O's'?
Couldn't resist...well I could but it's just too good
64mm for my regular LED downlights. I agree about the step drill, makes nice holes in sheet steel and plastic.
20mm,25mm,32mm,38mm and 51mm for brass bushes. 64mm for recessed PIR's. 75mm for the fire cans I use and 90mm for tilts. 114mm for 4" ducting.
  • Agree
Reactions: Dave OCD
as lee's post . except for the 114mm. for that i use apprentice's head.
Ive 2 of every size from 20mm up to and including 83mm, and 1 of 105mm or thereabouts, and 1x 114mm which was the one I meant to buy when getting the 105 or thereabouts. Anyways it was way too tight for fans and grills lol
Get a set of armeg hole saws for the smaller sizes! Then just buy the bigger sizes as you need them.
Marti
Poole, Dorset
Business Name
Sore Holes! What should I use?
Marti,
Leesparkykent,
