We have some more coming don't worry. Might change the agree to a tick again though.
I like the agree button, it is unambiguous.
This is at times a highly technical forum with many different opinions.
I do like the subtle difference between like and agree.
for instance,
a new diy member joins and says,
help me, what is wrong with my fuse box, it is tripping RCD no2 every day shortly before I get up at 7am.
There will be the following reply's, amongst others.
what time is your heating / immersion heater set to come on in the morning?
(like)
Have you had any work done recently?
(like)
it sounds like your immersion heater may be the problem, suggest you get a spark in to check it out.
(like)
I think the best thing to do would be to turn the timer on the hot water to off before you go to bed and see if it happens in the morning. if it still happens, do the same with your heating system. also check that there are no other things that come on at a pre set time first thing in the morning and try to rule them out by turning them off.
(agree)
