W
Wunga
Hello folks.
I have had a complete house rewire last month and all 17th edition certified.
The electrician also wired up the new oven and hob.
My question is this: When I switch on the hob at the wall socket, it also seems to bring power to the oven as the timer starts to flash which is quite annoying.
I checked behind the oven and it appears both the hob and oven are wired into the CCU, therefore this would appear to explain why the power supply to both oven and hob are controlled by the 1 switch above the worktop.
Is this the correct wiring procedure, and if not, am I within my rights to recall the electrician to rectify it?
Thanks in advance for any feedback.
Cheers
Cheers
