B
Bensen
Hey what kilowatt showers can be feed off 6mm cable and which need 10mm? I guess the distance from the fuse board also needs taking in to account?
Discuss Size of shower cable in the UK Electrical Forum area at ElectriciansForums.net
Yep, lets see what the new guys here think of that when they get in from the 5 week training courses they attend during the week.And therein lies the problem.
in this case what the op was asking is ohm's law, the basic's of the basics.
V=R/I
I=R/V
R=IxV
bassically to start with a 10kw shower would be 10,000 / 230 = 43Amps
so now you have your design current for your cable calc.
the cable you need for a 10kw shower depends on installation methods (clipped direct)
if it has loads of insulation along the route and other factors you might need a 16+mm cable (this is why we calculate cables in the first place)
and to answer your question, the members here get that bored and wound up from giving people the same advice everyday on how to wire a shed they get ratty
Please can you fix your typo in the first quoted post before it gets taken as gospel by trainees etc.i think you have a typo mate.
you put 5.8kw i think you mean 8.5
Enough!! You're the one trolling for trouble here so stop it and leave moderating to the Moderators.So you are back and immediately you are being a dxck.
Please don't hand out detailed advice on the public forum
I swear to God you're gonna start seeing some abuse in a minute if you don't settle down!!
NOBODY HERE HAS ABUSED YOU YOU PITY SEEKING LOP!
It wasn't your suggestion about using 6mm cable on an 8.5kW shower that was wrong, this was just inaccurate. What was wrong however was for you to 'suggest' in the first place! What is so bleeding hard for you to understand?! You've been told God knows how many times already!
No matter how much detail you go in to about cable calcs, design, derating blah blah blah, when you are describing how to do something to a plumber on an ELECTRICIAN'S forum, all they will see is "put an 8.5kW shower on a 6mm cable".
Please tell me that this has sunk in finally?!
Its time to move on lad.
Quite right Sir!
The first step of which is you placing yourself quite neatly into yet another allocated slot on my ignore list.
Good day to you.
I've just said 5 hail marys while standing on the naughty step !
He's a Tory, he likes attention lolEnough!! You're the one trolling for trouble here so stop it and leave moderating to the Moderators.
V=I/R
I=V/R
R=VR
One right. Have another attempt. :smile5:
V=IR
I=V/R
R=VI
i just swapped them all around after marvo asked.
they are wrong yes
V=IR
I=V/R
R=V/I
im too tired i cant think straight lolHooray! :clap: arty: :drummer: :17: :clap:
Rollocks, you flucked up, end of :biggrin:im too tired i cant think straight lol
Sorry mate but you've had an absolute mare here! Time to log off and try again tomorrow [emoji1]im too tired i cant think straight lol
You all need to go to bed, when dealing with AC we use Z not R, V= IZ
Cheers
Very broadly speaking up to 8.5kw on a 6mm
8.5kw to 10kw will need a 10mm
Using 6mm to supply an 8.5kw shower is WRONG
Is it right or wrong?
Yeah but no but yeah but no but............Using 6mm to supply an 8.5kw shower is WRONG
Possibly, I'll let you know.So.... that's a definite maybe then Trev?
Depends,
Is it connected to a plastic, or metal clad consumer unit ?
If in doubt, consult a plumber.:icon12:
So you used to be indecisive but now you're not sure?
The honest answer is (It depends) and that goes for me, you, the shower, the cable, and life in general.
I 100% asked for it though lads. Hold my hands up to that one.
Three days, thirteen pages, 149 posts and we're still arguing about what size wire to use for an electric shower and not a Electrical Trainee in sight!!
A whole forum of properly trained skilled tradesmen can't decide whether to use 6mm or 10mm cable to wire a .........
............ shower??!! :biggrinjester:
And we haven't got to the CU that it's going to be terminated in yet .... Steel or plastic???
Reply to Size of shower cable in the UK Electrical Forum area at ElectriciansForums.net
