Discuss Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
So its the route of the cable that defines that its a ring or a parallel circuit??
Remember what I said at the end of my post !!
Yea but no but yea but lol.
So you have two 2.5 cables feeding a single double socket on a 32 amp mcb
Is it a ring main, or a radial with two 2.5 feeds ??
And here we go again lol
Yea but no but yea but.
If the cables were identical lengths and running the same route it could be called either in theory....but if you called it a parallel cabled radial you could put a 40A MCB on it whereas if the mood took you to call it a single socket ring final you'd only be able to put a 32A MCB on it..........So you have two 2.5 cables feeding a single double socket on a 32 amp mcb
Is it a ring main, or a radial with two 2.5 feeds ??........
It's probably more likely to occur when sockets have been removed from a ring circuit just leaving one remaining in which case the two cables would likely be different lengths and following different routes so it wouldn't qualify as a parallel cabled radial so it would have to be considered an rfc.To me two cables running to one socket outlet, which follow the same route etc. would be a parallel circuit and not a ring final circuit, as the conductors do not form a ring. It would also be quite idiotic for one BS 1363 socket outlet. I have seen it done before and frankly I cringed.
Didn't know you had showers in those straw/mud huts over there Marv.I'd be interested to know if there's actually a reg that forbids it in the UK, I know there isn't in our domestic regs. As said already, it's common practice with cables in larger distribution networks but the logistics of ensuring identical lengths, routes and connecting a parallel cabled domestic final circuit would make it a bad idea.
I find the most usual case is that some people bizarrely assume that sockets must be wired as a ring and therefore bring a parallel feed to one socket, e.g. in a garage.
Reply to Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
