H
Howard Thomason
HI Guys, so looking for some advice I've had a re-wire for our new kitchen all was going to plan until yesterday when I realised that my changing of appliance could be a issue.. I told the electrician I was getting a range style cooker so he wired up for this, I changed my mind after seeing the prices and carried on plodding away fitting the kitchen, with what would be a ikea induction hob 6. 5 kw no cable included. And Ikea oven 2.48 kw, I have absolutely no electric knowledge and my electrical is on holiday he is due back in 10 days to fit sockets etc.
IS it possible and safe to run these from the same 32 amp fuse? the consumer unit is directly right by the dividing wall very close. It looks like a 10 mm cable, as far as I'm aware he has prepped for a cooker switch on the wall and incoming range power cable at just above floor level, there is also a separate white cable that runs above for an extraction fan as pictured tho it looks like it may be run from the 32 also. I've attached lots of pics hopefully someone can help me out I'm confused as I have seen lots of posts saying it's fine but others saying it nerds separate fuses. Cheers guys
