P
penguinlicker
Hello,
The shed is supplied with 6mm Swa on a 25amp rcbo. Inside the shed is a 20amp socket circuit and a 5 amp lighting circuit.
Can I add a junction box to the supply cable about mid way and radial off that box to a double socket?
a 32amp radial requires 4mm, and a 20amp radial is 2.5mm. But is there anything saying I can’t add a double socket to a shed supply cable when the cable size and rcbo both seem satisfactory?
thank you for reading and helping if you can
