My old ones were like that but recent ones are tightened by hex-wrench, which is not as good, imho.
You could change the bolts for hex-head ones, though often Alla bolts are in higher tensile steel (10.9 or 12.9, not the common 8.8)
Or get a set like this:
The eye-wateringly expensive Milwaukee knockout punch kit is an amazing tool for anyone punching a lot of holes.
there's a simile for that, but it would get me a ban.
  • Funny
Reactions: pc1966 and loz2754
Just took a look at the M18HKP-501CA kit for the princely sum of £1,079 and it looks really smart.
Alas, I don't get as much opportunity to punch holes as I might like, so my money is better spent elsewhere. On beer, for example, to cry in to...
Thanks @pc1966, that looks like a good set of hex sockets. I do have hex bits, but then you have to put them in an adaptor for a socket, which makes it a bit unwieldy, a bit wobbly, and of course increases the height when you want to go low profile. However, I'll probably get that set anyway.
I must have dozens of "sets" of assorted bits, sockets, security bits...I really must stop buying stuff!
(Clearly...I won't!)
Reactions: DPG and pc1966
Here is a hole punch in parts, dashed line where the metal sheet would be:
Ahhh now it makes sense. Milwaukee do a version that goes in a cordless device that does the punching for you nut knowing them it'll be about 300 quid. EDIT 300 quid? Jesus H Christo it's £1100.
So I'm presuming you just tighten the nut and it cuts through?
I bought a hole punch years ago for cutting a tap sized hole into a stainless steel sink, I lent it a plumber the other year who was mesmerised by it and said it was the best thing he has ever used, never really thought about them for 20 or 25mm holes, I just use a hole saw or step cutter.
As for using impacts for joist drilling, why would you not use a cordless angle drill? perfect tool for the job.
Using an impact for joist drilling is best when using the Bosch blue self pulling spade bits.
It's noisy yes, but almost effortless.
Reactions: nicebutdim
Or wood beaver style bits.
I quite fancy an angle impact driver as my angle drill just about keeps up with joists.
I've tried those bosch bits but once the threaded bit goes blunt on the end (which is quite quick) the bit is useless. I use the Dewalt extreme bits which cut just as quick but can be re-sharpened a good few times if you have a bench grinder in the van.
I have the Bosch screw in flat bits too… Used them with a brand new dewalt combi…. 7 holes, and the drill went up in a puff of smoke.
Got a replacement, no quibble.
Reading back the thread, there was a few suggestions for an impact…. Don’t!
Then you won’t be tempted to use it for tightening up mcb terminals!
  • Funny
Reactions: pc1966 and pirate
Bought a set of those Dewalt extreme flat bits for about £11 in a Toolstation offer. Can't fault them as spade bits go.
Reactions: pc1966
I like that we can call them that, without fear of reprimand!
Spade?
How do you confuse a plumber?
Show him three spades and tell him to take his pick.
  • Funny
Reactions: pirate and pc1966
Type of drill to get?
Electrical Tools and Products
Chriel90,
littlespark,
