Feb 19, 2021
uk
Business Name
Jelectrics
Will new MK Honeywell RCBOs fit onto the din rail of a MK consumer unit.
See attached pics of the existing consumer unit.
I have been asked to replace this consumer unit with a new dual RCD unit as the existing unit has no RCDs fitted. However because it looks like the consumer unit was installed and then the cupboard fitted around it, it would be very difficult to replace. The other option would be to keep the consumer unit but replace the MCBs with RCBOs. A wholesaler has quoted around £30 per MK RCBO but I have seen online RCBOs by Honywell MK
( Honeywell are the owners of MK) for around £13. Does anyone know if these new RCBOs will fit on the din rail of the existing consumer unit? Thanks for watching.
Check this thread, from the MCB model numbers this is an old MK Sentry Board
https://Nope/threads/mk-sentry-rcbos.237249/
But is there really no way you can replace the Consumer Unit?. It looks Plastic and technically this is practically a board change in all but name since you are replacing all of the protective devices.
Looks like that link is not allowed replace NoLinkingToThis with screwfix dot com
The legs on the bus bar are too long for the new rcbos
uk
Business Name
Jelectrics
Replacing MCBS with RCBOs
Domestic Electrician Forum
whatever,
bill01803,
