Currently reading:
Lights in porch soffit
Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Minor or Major..
you have Minor works or Electrical installation....!!!
if new circuit then EIC
if spur from circuit MW
plus its Notifiyable to LABC
ip55, are led not classed as elv? and does that not make a difference? been reading lots of things and they all contradict....
So if fitting with 12v does this make a diffence? (dam my head hurts)
nope not all outside fittings are ip 4 rated some are only ip2 so not such a stupid answer was it. know it all
moisture in the air has no effect on electrical fittings i,ve seen plenty of batton holders under open porches with no problems. so your post was pretty stupid
ELV wiring (data, coax etc) doesn't need notifying, but if you're installing MR16 lamps the chances are you'll also be installing transformers, which use a 230v feed.
you should remember that this is a fourum. not a stage for you to have a pop at other people or make out you know more than anyone else
please explain my "POP" and also explain "know more" than any one else..!!
oh and for you little childish comment of "know it all" you contradict your self in so many ways!!
moisture in the air corroded through a 12" x 9" RSJ on my property. buggered up the electrical fittings as well.
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
