Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Minor or Major..
you have Minor works or Electrical installation....!!!
if new circuit then EIC
if spur from circuit MW
plus its Notifiyable to LABC
ip55, are led not classed as elv? and does that not make a difference? been reading lots of things and they all contradict....
So if fitting with 12v does this make a diffence? (dam my head hurts)
nope not all outside fittings are ip 4 rated some are only ip2 so not such a stupid answer was it. know it all
moisture in the air has no effect on electrical fittings i,ve seen plenty of batton holders under open porches with no problems. so your post was pretty stupid
ELV wiring (data, coax etc) doesn't need notifying, but if you're installing MR16 lamps the chances are you'll also be installing transformers, which use a 230v feed.
you should remember that this is a fourum. not a stage for you to have a pop at other people or make out you know more than anyone else
please explain my "POP" and also explain "know more" than any one else..!!
oh and for you little childish comment of "know it all" you contradict your self in so many ways!!
moisture in the air corroded through a 12" x 9" RSJ on my property. buggered up the electrical fittings as well.
now to bring some controversy into the equation. its in a porch. it's attached to the building fabric. so not notifiable. minor works certificate.
i may be wrong. but as i understand part p, outside electrics, as in remote from the house, garden, shed, ponds, etc. are notifiable. anything attached to the house, e.g. porch lights, security lights etc. are not notifiable
sent me home with a bunch of bananas , mate.
As per EGtBR (p60) it includes "Outdoor lighting or outdoor power installations" with no mention of being screwed down.
yes. agree with outdoor lighting/installations. but anything fixed to the fabric of the building is just an extension to the indoor installation as if it were an extra light or socket in a room.
I'm not sure I agree with this, can't really see the difference between an outside light attached to a post or the house, both are supplied from the house!
I think it's more of a special location because of the exposure to the elements, like exposure to water jets in a bathroom, steam in a sauna etc.
Funnily enough I was about to ask this same question, as I also read somewhere that if the fitting is attached to the building then it does not need notifying. Can anyone else clarify this ??
i think its an Outdoor light and should be treated as such..!
so what if he fits an outside door to the porch? it's indoors then. will re-read part p when next i get bored out of my skull.
my interpretation of part pee exactly.
So can you get out of having to notify work in kitchens and bathrooms by screwing the fittings to the fabric of the building?
still attached to the fabric of the building.
tel has this right
light fixed to outside wall attached to building doesnt need notifying if not a new circuit
a socket does as this could be used to supply a cable that crosses the garden
(i)
The installation of equipment attached to the
outside wall of a house (for example security
lighting, air conditioning equipment and radon
fans) is not notifiable provided that there are
no exposed outdoor connections and the
work does not involve the installation of a
new circuit or the extension of a circuit in a
kitchen or special location or associated with
a special installation.
I would say that Tel was right and it is not notifiable, as long as it adheres to above taken from the Part P silliness.
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi folks, I have been out to quote for a soffit lighting job. I have done jobs like this many times but usually only installing lights in the top...
Evening all, Installed many extractors, but this is a first for me. Customer wants the fan vented out through the soffit, with an inline extractor...
Hi all, The service cable is on the outside of my wall in the porch. What’s the best way to cover it with complying with current regulations...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi, I want to add a PIR to a porch light but I want the original light switch to still behave as it always has. i.e. both the light switch and the...
