Currently reading:
Lights in porch soffit
Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
now to bring some controversy into the equation. its in a porch. it's attached to the building fabric. so not notifiable. minor works certificate.
i may be wrong. but as i understand part p, outside electrics, as in remote from the house, garden, shed, ponds, etc. are notifiable. anything attached to the house, e.g. porch lights, security lights etc. are not notifiable
sent me home with a bunch of bananas , mate.
As per EGtBR (p60) it includes "Outdoor lighting or outdoor power installations" with no mention of being screwed down.
yes. agree with outdoor lighting/installations. but anything fixed to the fabric of the building is just an extension to the indoor installation as if it were an extra light or socket in a room.
I'm not sure I agree with this, can't really see the difference between an outside light attached to a post or the house, both are supplied from the house!
I think it's more of a special location because of the exposure to the elements, like exposure to water jets in a bathroom, steam in a sauna etc.
Funnily enough I was about to ask this same question, as I also read somewhere that if the fitting is attached to the building then it does not need notifying. Can anyone else clarify this ??
i think its an Outdoor light and should be treated as such..!
so what if he fits an outside door to the porch? it's indoors then. will re-read part p when next i get bored out of my skull.
my interpretation of part pee exactly.
So can you get out of having to notify work in kitchens and bathrooms by screwing the fittings to the fabric of the building?
still attached to the fabric of the building.
tel has this right
light fixed to outside wall attached to building doesnt need notifying if not a new circuit
a socket does as this could be used to supply a cable that crosses the garden
(i)
The installation of equipment attached to the
outside wall of a house (for example security
lighting, air conditioning equipment and radon
fans) is not notifiable provided that there are
no exposed outdoor connections and the
work does not involve the installation of a
new circuit or the extension of a circuit in a
kitchen or special location or associated with
a special installation.
I would say that Tel was right and it is not notifiable, as long as it adheres to above taken from the Part P silliness.
(i)
I re-read this and would agree with Tel. Less money to pay Elecsa then as I've always notified outside lights!
the bit about exposed outdoor connections. one could argue that this would make a socket outlet notifiable, but then if it was IP55 with a flap on, there's then no exposed outdoor connections, so it would be non-notifiable. typical part pee confusion.
Typical Part P confusion - defintely, however I would say that an outdoor socket is always notifiable.
(i)
I stand corrected.
outside sockets are notifiable mate its in the elecys guide to building regs
the installation of a socket outlet on a external wall is notifiable , since the socket outlet is an outdoor connector that could be connected to cables that cross the garden and requires RCD protection
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
