M
Maximus Rumpas
Hi,
I would like to ask your advice about how difficult it might be to pull cables through 20 mm plastic conduit. (easy, moderate, hard, impossible)
I am running two separate lines for a cooker and hob in 6 mm2 single core stranded cable. Both runs will follow the same route.
4 meter run from distribution board via 90 degree inspection bent to an inspection box next to soil stack.
Next 2.5 meter run through Bathroom/Kitchen wall to an inspection box under sink (minor set to allow for wall levels)
Then either
4 meter run, chased into wall via 90 degree inspection bend to a third inspection box.
or
4 meter run via 300 mm drop to Floor level - two 90 degree inspection bend to the third inspection box.
Lastly 1.5 meter run to cooker or hob isolation switch.
On completion permanent access to inspection boxes - limited access to 90 degree inspection bends.
Your thoughts please.
Kind regards
Max
Thanks Sintra,
Due to limited clearance in some areas I would like to avoid using a larger conduit if it were possible to use 20mm. If the advice is that it is impractical then I will have to use a larger size.
Max
I'm not understanding you? Can't you just tell us how many cables are in any one conduit and the sizes of the cables? You will struggle with 6mm in 20m conduit a specially with a bend. I think that's a no go
Hi Gazzaabc,
I thought I had - separate feeds to cooker and hob in 6 mm2 single core stranded cable Live, neutral and a smaller earth. Three cables in total in one conduit run. I thought I might struggle and that I should go for 25mm but wanted to check first.
Kind regards
Max
Max if your using plastic pipe you can buy 2 types of elbows! Buy the larger type. it's a bigger and longer bend but its not as harsh on the bend as the smaller one and makes life a lot easier.
If the earth is smaller you will defo get 3 cables down a 20m pipe if only 2 of them are 6mm. You won't even struggle
OP stated "I am running two separate lines for a cooker and hob in 6 mm2 single core stranded cable. Both runs will follow the same route." I am taking this as 2 circuits 6 x 6mm singles.
Hi Sintra,
O, I see how I might have confused you, sorry. One run for the cooker and a second for the hob. each conduit carries 2 x 6 mm2 + 4 mm2 earth. Apologies to all.
Max
Advice on Pulling 6 mm2 single core cable through 20 mm Conduit
Maximus Rumpas,
Engineer54,
