SKY
Been asked to help a friend wire his new boiler.
I'm used to valiants but they seem to have changed the PCB on the newer boiler.
Old boiler had.
Live (brown)
Neutral (blue)
Earth
Switch live (black)
Pump (black)
New boiler has the green plug on the left with 4 terminals. (Live, N, earth and RT)
Am I correct in thinking the following:
Live , neutral and earth as normal
Switch live in with the live
Pump in RT
Remove link on the 24v side
Thanks chaps
I'm pretty sure the boiler has pump over run and a separate terminal for the pump connections. The control wiring should be fed from the PCB to abide by manufacturers instructions.
Ecotec 418 wiring
Central Heating Systems
SKY,
Leesparkykent,
