K
Kicksnj
I bought a concession trailer that was all propane. Being the town I'm in is so strict about propane, l gutted it out and now making it all electric. Running on 2 generators.
So my question is about wiring. The interior is all stainless steel. I have mounted all metal conduit to the walls. I am using only GFCI receptacles. So do I have to run a grounding wire to each receptacle or can I just run 1 wire to ground the conduit and then just run a wire from the receptacle to each receptacle box. Remembering too that this is a MOBILE unit running off of generators with CFGI's in them. So really my only grounding is the rubber tires on the trailer. Any help would be much appreciated.
