Search the forum,
Discuss LED RGB STRIP + L CONNECTOR (PLEASE HELP) in the UK Electrical Forum area at ElectriciansForums.net
Hi, my names Ric. (Apologises for the essay)
Im new here but with only one question, or problem!
Ive purchased an RGB LED strip to go behind my TV and to avoid bending the strip round the 4 corners of the TV, Ive also purchased L Shape RGB Strip Connectors.
Now since purchasing Ive noticed that on the strips cut marks it is written + B R G in that order, and the L Connectors Ive purchased are written + R G B
My question is are these compatible and has anyone ever come across this before because I cant seem to find Connectors that have the same + B R G order as the strip Ive bought.
As long as each strip lines up... ie the + to the inside of the corner, then the connector is simple a set of wires. It shouldn’t matter.
I put a set of these down the doors of a glass cabinet and soldered wires to each point to pass where the hinges were.
Reply to LED RGB STRIP + L CONNECTOR (PLEASE HELP) in the UK Electrical Forum area at ElectriciansForums.net
