Markc
- Reaction score
- 147
Your last post does now make more sense. It's not how I first thought that you can use an existing system. It is still up to the assessed company to provide proof from first contact to completion that they were the installing company, all be it via sub contracted labour on certain aspects. So on that first job it would be a case of not only ensuring faith from the client to the contractor that they will achieve MCS but also fund sub contracted labour for the installation.
If however it isn't the case I don't understand how you can possibly use someone else's installation to gain MCS like you said in an earlier post? Am I correct is assuming if you know of an installer who is MCS you could contact them to ask if you can use their installation as an example of works for you to achieve MCS rather than having the expense of installing a system yourself? If that is correct it is that, that sticks in the throat a bit.
Thanks for the last post Treadwarm
