seamus
sligo
Ireland
Im wiring a few lighs in the shed to a small fuseboard and eco flow, 3 light bulbs and 4 switches, ive followed diagrams but I've obviously made a mistake if anyone can spot it, id appreciate it.WhatsApp Image 2025-08-06 at 20.51.12_c683ead3.jpg
I presume it went bang when you tried the switches?
  • Agree
Reactions: DefyG
Im wiring a few lighs in the shed to a small fuseboard and eco flow, 3 light bulbs and 4 switches, ive followed diagrams but I've obviously made a mistake if anyone can spot it, id appreciate it.View attachment 122990
No neutrals should be connected to the Light switches.
Yes with Live one side and neutral the other it was bound to go pop! on both S1 & S2
yes, worked then went pop, chat gbt advised connecting brown from power in s1 and s2 to l1 and l2, and brown from bulb 1 and b2 to l2 on s1 and s2, then removing blues from common on s1 and s2 and joining them with a block, still not working
  • Optimistic
Reactions: DPG
Please get someone who knows what they are doing to help you out.
Wiring using Ai is a terrible idea,ai does not understand country differences and often mixes them and states things as fact.
Get someone professional in for a few hours.
Without going into detail, and not giving a step by step guide.... maybe an education in simple circuits?
(This is the moment i look at the internet for an easy to follow diagram, and i cant find one!)
Your simple circuit is a source, the Live cable, going to a switch, coming from the switch to a load, your light, and back to the source as a neutral.
As mentioned, there are no neutrals connected to a switch, but they may be present in the box behind.
Just because its blue, it doesn't mean its a neutral. This is where AI gets it completely wrong.
Redo your diagram, ignoring the earths for the time being, showing just 1 switch, 1 light, and we can expand help from there.
No need. I’m sure it will give him a clue.
However, OP not been seen for a week
Let's hope "chat gbt" didn't give him even worse advice.
  • Funny
Reactions: DPG
sligo
Ireland
novice wiring light switches
DIY Electrical Advice
Thread Tags
Tags Tags
wiring
seamus,
Ventricular Fibrillation,
