vonjuan
Sheffield
United Kingdom
New DIY'er here so apologies in advance if this seems obvious, but I would rather check first.
I want to connect my 2 loft lights to my lighting spur with a switch in the middle.
If my spur 1.5mm twin and earth comes into my switch box, can i connect the live wire to the common terminal, with the neutral wire connected to the neutral wire of the 1.5 twin and earth going to the 2 lights (with a wago connector), and the earth also in a wago connector between the two. Then the live wire of the twin and earth going to the 2 lights connected to the L1 of the light socket?
Then the 2 lights and the twin and earth will have each of the live wires connected in a wago connector, and the same for the earth and neutral wires.
I think what you’ve described is correct.
Sheffield
United Kingdom
Radial spur to Switch to loft light wiring question
vonjuan,
littlespark,
