P
phawk
Pretty sure I know what you will say but I wanted to run it by the forum before I give the client an answer......
I've been asked (for some reason) to install a socket in their loft. The problem is that the only accessible cable is the 1.5mm T&E permanent feed for the loft light. Is there any way of doing this whilst complying to regs? Possibly break into the cable with a JB then fit a 5A fused spur before the socket?
Before you ask....
The loft is boarded, there is no access to any other cable.
No, I do not know why they want a socket in the loft, and neither do they!
Before you ask....
