DERECK
hi everyone my sockets stop working in house when i went to fuse box no fuse were blew but there was a lot of heat coming from fuse box. but when i pulled the fuse for sockets my lights went out and when i put it back in sockets where working but lights were out where i was so went into kitchen turn on light there and all lights where going on from one switch and of and this was the same from any switch so i removed lights fuse from box but lights still on and when i used any switch still turning of all lights in house with 1 switch so i took out the fuse for sockets and again lights went out so i left out socket fuse and replaced light fuse and all lights work as they should check wires at fuse box to see any red wires from the socket fuse where touching wires from wire coming out of the fuse that runs the lights i could not see anything Burt or of colour. my fuse box is old fuse wire and has 3 red 30 amps 1 blue 15 amps 1 white 5 amp and green 45 amp. thanks for tanking the time to read this i hope someone can help as i so confused all that can happen and not even blow a fuse.
