Discuss The Ring is dead, long live the Radial!⚡ in the UK Electrical Forum area at ElectriciansForums.net
Me thinks they do things slightly differently in the US. Might be wrong.There is a very strong requirement here for dead testing before the circuit is energized, both for a full installation and for simply adding a new circuit to an existing system. That applies for domestic, commercial and industrial stuff.
Not just IR testing to see if the cable is OK, but also testing R1+R2 (live and earth resistances) both to verify socket & SP switch polarity, and also from the boards Ze (earth loop impedance) to check the circuit's Zs value is going to allow fast enough disconnection by the choice of fuse or MCB, etc.
USA use the tried and trusted 3fold Test. .Me thinks they do things slightly differently in the US. Might be wrong.
1.it works.
2 it not work.
3. it goes bang.
first 1, fine.
2nd one call supervisor.
3rd one run away.
my preference is rings for kitches/utility rooms. 2-3 radials for rest of house. (average house, not a mansion).When we buy a house later this year .I am doing a radial rewire . Might mean a huge consumer .But if possible will make every room radials etc
All socket circuits fitted with £150 AFDD as 18th Amendment 2 is looking like?When we buy a house later this year .I am doing a radial rewire . Might mean a huge consumer .But if possible will make every room radials etc
"It was like this when we purchased it " !All socket circuits fitted with £150 AFDD as 18th Amendment 2 is looking like?
And coin meter ?I built and wired my own house around forty years ago. If I could go back, with what I know today, each kid's bedroom would have had its own radial and MCB.
Then a power surge and everything’s goosed? ?You can now buy an afdddddrcbbbbo for £149.99
4 If you are lucky something smells funny ,USA use the tried and trusted 3fold Test. .
1.it works.
2 it not work.
3. it goes bang.
Reply to The Ring is dead, long live the Radial!⚡ in the UK Electrical Forum area at ElectriciansForums.net
