Discuss The Ring is dead, long live the Radial!⚡ in the UK Electrical Forum area at ElectriciansForums.net
There is a very strong requirement here for dead testing before the circuit is energized, both for a full installation and for simply adding a new circuit to an existing system. That applies for domestic, commercial and industrial stuff.
Not just IR testing to see if the cable is OK, but also testing R1+R2 (live and earth resistances) both to verify socket & SP switch polarity, and also from the boards Ze (earth loop impedance) to check the circuit's Zs value is going to allow fast enough disconnection by the choice of fuse or MCB, etc.
Me thinks they do things slightly differently in the US. Might be wrong.
Radials are usually quicker to install and quicker to test - so cheaper on labour, material wise breakers are same price and cable works out about the same or actually cheaper without the return leg.(Eg 30m of 4mm or 60m of 2.5mm) I do mainly commercial and use 25a 4mm radials a lot for runs along store walls etc. Also wiring rings in singles in containment is a massive pain to keep the right “leg” together and also twice as many drums to get tangled up and wrapped round your ladders ? rings have there place still, probably make more sense in houses and offices kitchens etc
When we buy a house later this year .I am doing a radial rewire . Might mean a huge consumer .But if possible will make every room radials etc
my preference is rings for kitches/utility rooms. 2-3 radials for rest of house. (average house, not a mansion).
New posts
Reply to The Ring is dead, long live the Radial!⚡ in the UK Electrical Forum area at ElectriciansForums.net
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
