- Reaction score
- 10,616
I expect the later easier if your in a wheelchair or elderly & infirmed.Isn't a switch inside a low cupboard at 450mm high easier to reach than an isolator above the work top? With its 600mm depth to reach over?
Discuss Can Plug Sockets for Dishwasher and Washing Machine be Placed in Under-sink Cupboard? in the Electrical Appliances Forum area at ElectriciansForums.net
Ok then; I expect the later easier if yourIf the kitchen is specifically for disabled access there are detailed guidelines on access and positioning.
Scottish Regs stipulate isolation switch above counter top for under counter appaliances. I always put Socket outlets behind the appliance fixed to the structure of the building. Regs are to be followed whether a new build or old.In a new build or major refurbishment, perhaps yes to comply with Part M Building Regs 'to assist people who have reduce reach'. But it only specifies min & max height of switches etc. Designers of new builds often use the central set of DP switches. What do the Building regs in Scotland state?
As regards socket outlets in cupboards, how else do you supply an appliances?
Yes that makes sense. If the elderly or infirm need to pull the appliance out to do a quick repair its easier if the socket is counter top. Can't imagine they'd get somebody able to do that for them.Ok then; I expect the later easier if yourin a wheelchair orelderly & infirmed
Should an appliance burst into flames having the isolator above and behind it isn't really much help.
I also agree there is little point in sockets behind appliances.
Only in Scotland does this 'reg' appear to apply.Scottish Regs stipulate isolation switch above counter top for under counter appaliances. I always put Socket outlets behind the appliance fixed to the structure of the building. Regs are to be followed whether a new build or old.
Reading instructions? What kind of a bloke are you!?I have seen appliance instructions which state not to install in front of a socket outlet. I assume that it's because the back of the appliance gets warm, which might affect the plug. (Think it was a dishwasher.)
If possible i have socket in andjacent cupboard. If not practical have an SFCU and wire the appliance to a flex outlet behind the built in appliance.So with a built in appliance where do you plug it in????
You giving too much credence to these 'engineers'.Oh come on now. Any appliance repairer will be capable of isolating an appliance and using a flex outlet, a cooker connection plate, or a FCU for disconnection of an appliance. If they are having to call an electrician for that they are in the wrong job.
What anyone does with an installation after I have completed the job is really nothing to do with me.Don't know about you but I don't want some heavy handed appliance swapper removing my FCU and disturbing the connections. Of course he'll test the ring end to end values afterwards. Won't he? Daz
I never called them engineersYou giving too much credence to these 'engineers'.
Well I've had calls from customers where they've paid companies for delivery and 'installation' of kitchen appliances only to be told that they can't connect as they're not insured or other such excuse - always flex outlet plates or SFCUs.
QUOTE]
So when the appliance fuse blows in the plug of the appliance... Not your problem I guess. THAT's why they should be in a cupboard as high as reasonably practical on the hinge side. Which fuse blows first, the FCU or plugtop. Answers on a postcardScottish Regs stipulate isolation switch above counter top for under counter appaliances. I always put Socket outlets behind the appliance fixed to the structure of the building. Regs are to be followed whether a new build or old.
Simple solution here. This is what kitchen fitters do to get round it.Perhaps the regulations have changed, in Scotland in the intervening 4 years
And helps to get a grip for pulling the damn things out when needed.My solution is a tray space in between a couple of the machines.
Reply to Can Plug Sockets for Dishwasher and Washing Machine be Placed in Under-sink Cupboard? in the Electrical Appliances Forum area at ElectriciansForums.net
