DanielF
I have an entry way that has 3 switches. One for the hallway, one for the front porch, and a third for a study outlet which is a room off the hallway.
I want to convert the switched outlet to a ceiling light that I am installing in the study. I would like the outlet to always have power and not be worked by the switch.
The complexity is that somehow the switch to the outlet also powers the other two switches for the hall and porch.
My first attempt I thought I had it wired correctly but when I turned the switch on and off for the ceiling light in the study it also turned power on/off to the other two switches.
I attached a diagram of what the existing wiring looks like and the ceiling light I would like to add.
Any suggestions are greatly appreciated.
We can see no diagram.
Reactions: James
If I understand correctly,you would switch off power and fit a wire link across switch you want permanent feed from,if you feel confident to do this.
Regards,S
Reactions: James
Think we need to see a picture first although this sounds a reasonable solution.
Reactions: James
Daniels welcome to the forum and I read your profile and I think you might be in over your head no offense but I can’t advise you on this matter. You stated you had already been doing some wiring and things are going wrong please hire a licensed electrician it shouldn’t take him over an hour at best
Reactions: Pete999
Converting an switched outlet to a light
DanielF,
Megawatt,
