May 24, 2020
73
80
93
Yorkshire
Other
I'm looking at installing a plastic distribution board to feed a 3 phase vehicle charger. I've never been clear on whether flats being present in a building automatically make the rest of that building count as domestic or not. My understanding of 421.1.201 is that it does.
The install location is a very damp cellar and I don't think a metal unit is going to last long down there - I've already ripped out metal junction boxes and galv conduit from there that have heavily corroded. The cellar's construction is a vaulted brick ceiling and brick walls with a stone floor. The floor above is also stone. There are no combustible materials present. There is also fire detection present where the unit would be installed.
I'm thinking of doing a risk assessment and installing an IP65 plastic enclosure. Can anyone see a problem with this?
Have you considered a stainless steel distribution board?
they are made for marine environments normally but would be suitable for any corrosive environment.
This is an interesting one.
I'd go with @James suggestion above.
Or a metal CU inside a plastic PI65 enclosure.
If you are going down this route I'd bung in one of these, so it's safer then normal.
Thanks, very good suggestions. I'd forgotten about the enviroburst things.
Never heard of them. Brilliant.
I think I’d have them as standard in boards.
Same here, never heard of them. If they really work, we should start a movement to reinstate the plastic CU, fitted as standard with these things.
Reactions: Deleted account
I don't have the regs with me but I'm not quite as sure. I've hit a similar kind of issue with a caretakers flat in a school, about 1% of the site.
There's a nice test of them here. "So I put some firelighters in the bottom of it...!". My kind of guy, no messing around!
Skip to 6 minutes in.
Yorkshire
Other
Installing a plastic CU for a vehicle charger
partplonker,
timhoward,
