E
ernest1990
Hi all,
I've recently replaced my 4 inch centrifugal extractor fan fitting in the loft. I was hoping for some advice on if this is wired up corrrectly. The fan itself is working well.
Old fan had timer, new fan doesn't have timer.
Both fans are turned of via the pull switch in the bathroom.
I wired it up to match the old wiring:
With the old fan, this worked with both switches turned on. With the new fan, when both switches are on, the fan runs constantly. If I turn the left switch off and keep right on, the fans works as expected (on and off using the pull switch in bathroom).
Wanted to check if I'm good to leave this set up how it currently is regarding those left and right switches. It doesn't have any issues in how it functions. I just wasn't sure what that left switch has to do with this new fan / how I've wired this new fan up and why it causes the fan to run when switched on.
Any advice is greatly appreciated.
Thanks,
Andy.
- First image attached is the old fan showing its wiring,
- Second image is the new fan showing the new wiring,
- Third image shows the existing switches next to the new fan (left off, right on).
Thanks,
Andy.
