Currently reading:
main cut out fuse
Discuss main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
L
lawmanxe
How do you pull out the fuse your self, I've phoned for permission to cut seal and got refused by dno and then went to the supplier they said I can as long as I test and leave certificate for them I'm really confused about changing a consumer unit and pulling the fuse. Help would be very greatful.
Right for a start if there's no seal has there been evidence of tampering? The question you should be asking yourself is are you prepared to take the penilties if you pull the fuse and it all blows up in your face. I work in and train the metering industry if there's a fault with the cutout I have seen evidence of what can go wrong in the way of bad burns etc. I would strongly recommend you contact your supplier who can arrange to get this work done for you.
If and I say IF the suppliers/DNO's were to do a 1/2 day course to gain the relevent knowledge, experience and more importantly the "permission" to remove seals then the whole better off we would all be.
Do as Tony says,but when the deteriorated copper conductors touch within the service cable or cutout,and 16000+ amps flow through them the copper vapourises in the back of your eyes, you better get a guide dog.
Not bad, why?
Because.... (and I'm guessing at what Tony was eluding to).....what's the maximum PFC you'd expect off a 230V domestic line? Do the maths in reverse and tell us what the Ze would be in order to get 16,000 amps flowing at 230V.
Or even, to give it some real-world clarity, at 245V
If it wasn't dangerous why should DNO engineer's wear IR gloves, gauntlets, full face protection and flame retardant clothing.
Most of the WPD lads around here wear 501's and a smile. Raybans for hot days only.
the point i`m making is pullin a bastid fuse has gone epic....
and i dont buy for one second that most in here havn`t done it because of `elf n safety`...so stop blaggin....
We'll all be tripping up over garage forecourts next week - best be banning those pesky kerbs and not minding when the alarm goes off.
Come on, were talking about the incomer which is protected at the supply transformer by what? 200A 250A 300A etc,different ball game.
60-100amps will f$*k you up!
isn't 30milliamp the upper limit of safe!
work safe, sensibly, use your skills/knowledge/training as you would always when working with electricity.
(its a fuse).........................
I supply my guys eye protection for when they clip cables, as yet no one has worn them for this, not because it cant happen but how unlikely, but if someone loses an eye not my fault I supplied eye protection
Reply to main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
