C
cdrive
Hi all, I looking at having a new solar panel system installed in kent and would like some advice if you could spare some time.
I have been looking at getting installed around 6-8 kw system. If I go for an 8kw system I would have shading issues on a bottom row of panels (spaced over two roofs and detached garage roof).
I could go for a 6kw system (over one roof and detached garage roof)I wouldn’t have any shading issues or I could go for somewhere in-between.
I have been looking at getting the power one micro inverters with either suntellite, 8.33 Gallium or solarworld all black panels. (Please let me know if they are any good).
The main reason I like the idea of the micro inverters is that I can see if any part fails very quickly and where it is (and sort it out myself if needed). The other reason is that I have been told that they produce better results as the start on lower power compared to a SMA string inverter for example.
What do you think would be the better way to go?
Have a good read at this thread Optimisers or micro inverter?
Thanks, I have just been reading that he main thing with enphase, why I ruled it out is that's its only 215w and the panels are 250w so I would lose peak power.
I know that they come with a 20 year warrantee, is there much difference in price
The 215w work well with 250watt panels. The inverter is always undersized for solar in this country
There are many opinions on this, without knowing more about the site I would avoid shading where possible, less is more at times..
Or, maybe an SMA with optitrac switched on, if system design works well with that...
The truth is no one really knows which will produce the most power, they will all work but which would be the best?
Ok, I'm guessing that we would have little chance of getting 250w in the UK. is there much difference in cost?
Thanks I didn't even know about optirac, I will look into it.
What about the fault finding, I like the idea with micro inverters you can see when a panel or inverter is not working and see where it is
Panel failure is very rare, by the nature of how they work, over time inverter failure is possible, my opinion is I would prefer a piece of electrical equipment mounted inside, in the dry and not on the roof mounted under a panel, scaffold @ £400 per time to change them if the company complies with the law, as I have said no one can prove which is best for performance it is just opinions.
What we do know is that a well designed system with a decent string invereter produces well for many years.
As was pointed out to me the other day, if each panel should have its own inverter why haven't any of the panel manufacturers built them into their panels or made them available in the UK.
http://www.pv-tech.org/mobile/news/canadian_solar_offers_250w_integrated_microinverter_ac_module
scaffold @ £400 per time to change them if the company complies with the law in UK.
With Enphase micro inverter system you will know exactly which inverter or module has gone wrong and exactly where that problem is on the roof and will be able to replace if without a full scaffolding, in most cases.
You can hire a tower at your local hire centre for about £40 a day which complies with all HSE requirements. Plus the replacement inverter is Free and the installer gets £125 to replace it.
Also if a string inverter system goes wrong see this current thread : http://www.electriciansforums.co.uk...orum/87196-five-days-without-solar-power.html.
you won't lose generation and import savings for days on end.
With respect "Five days without solar" is an install fault due to the PV being conected to the supply wrong, it is not an inverter fault.
I fully understand that you are a big believer in enphase, but how many panels have you personally had fail?
Without assessing the site, there is no way of knowing exactly how much of a shading issue you believe you have. Sometimes it is much less or much more severe than a customer realises.
Having shading doesn't mean you automatically need to have MI or optimisers. Get someone to come in and design you a system properly.
I won’t have any shading issues on the garage 3kw system.
The house will have shading issues (this time of year) if I use the on the long roof at the back (chimney on the back was removed last week), see attached photo taken at the weekend @11:45am
But won’t have any on the side of my the trees on that side are toy trees only 15ft high, but can only fit 2.5kw system.
I’m thinking that if I use the garage 3kw with string inverter in the garage. Use the side of the house 2.5kw and maybe the top of the back roof for another 1-1.5kw as it won’t have shading issues that high.
What size supply do you have in the house? if only single phase then you'll have to apply to DNO to connect more than 16a (3.68kW). If you have 3 ph then you'll be ok.
The DNO may let you connect 8kw on single phase without any upgrade works, if not then you'll have to pay for upgrades (poa with DNO)
I only have a single phase, So I would have to apply
One of the quotes that has come it uses suntellite panels and solis 3600 inverters, are these any good?
If you are happy with the standard of work done by the aerial fitter and conservatory installer, then go with the cheapest you can get.
PMSL, there was a chimney there which we had removed last week for the panels, the conservatory was all ready there when we moved in and will be replaced but as it not causing any issues at the moment, it can stay as we just had all the windows doors and guttering replaced.
I rather pay for new panels :-)
It was the ariel cable and guttering / downspout that I was actually alluding to, the cable should have been sorted when the chimney was done.
Is is simple enough to get a proper shading analysis done on site, either using a Solar Shading Meter with the MCS Overlay or, better still 3D modelling in PVSol, - the better installer is more likely to use the latter to give you a real analysis and they can do an animation of the effects to bak up their recommendations.
We would only supply from these inverter manufatcurers:
SMA (string)
Power-one (string and Micro)
Enphase (micro)
SolarEdge (inverter and optimisers)
Panel choice is a bit wider depending upon budget and aesthetics.
Thanks I be going for the SMA or power-one string inverters as they seem to keep coming up with good reviews. I will go back to them and ask if the do can do a proper shading analysis.
They have all said if I just put a 3kw system on the roof, it would avoid the shading at the bottom.
as for the panels I would like them to be all black giving good performance. I would like the Sunpower 327 but they just cost too much
Could go for the Benq 325's same cell as the Sunpower's - we find that the economics adds up as the other costs are the same as for a smaller system and it's only an incremental panel cost.
Other costs: Design, paperwork, scaffold, AC cabling, DC Cabling, inverter, labour, mounting, insurance, QMS, are the same (well inverter may be £100 more..)
get them to paint the exposed ends of the rails black as well :)
Thanks for that I will find out how much they are compared to the Solarworld ones. I like the painting exposed ends black tip as well, that's the sort of finish I would like
Ask someone from the forum to quote then - most of us here do that sort of thing as standard practice without having to be asked :)
With all the advice that is available for free from here, it's only fair to give someone a chance (Kent is too far for us :)
New system, string or micro inverters
cdrive,
cdrive,
