- Reaction score
- 507
Where are you based?
Discuss advice needed re electrician problems in the DIY Electrical Advice area at ElectriciansForums.net
Did they promise you a cert? It could make interesting viewing if your get one. Remember, its not just about a cert - if they are registered you should get a Part P certificate later. Are building control involved? Did you need to have planning permission?do you think I have good reason to complain, I know nothing about electricians , I just want my cert so I can get my extension signed off
they are advertising at the local shop I will pick a card up 2 moz, the name on board is coming up with nothing when I put it in
Reply to advice needed re electrician problems in the DIY Electrical Advice area at ElectriciansForums.net
