Discuss 3 phase USA 3/60/220 to UK 3 phase is it doable thanks in the UK Electrical Forum area at ElectriciansForums.net
You want to run a 220v device on 400v?
a transformer may be suitable but motor will run slightly slower due to the reduced frequency.
what is the device to be powered?
A transformer can be used to correct the voltage, but the difference in frequency might be a problem. All AC motors that don't have variable-speed drives will run too slowly and might not work correctly. You would need to seek advice from the manufacturers as to whether it is capable of operating at 50Hz. If not, a frequency converter will be needed which is significantly more complex and expensive than a transformer, or some motors might need changing, or whatever. One would need very specific information about them to decide which methods would be best.
I've a few machines running on 220v three phase.
The motors on my machines are servo, so are controlled by individual yaskawa drives.
I am using a 400v - 220v transformer.
It might be worth finding out if the machine has PNP or NPN components.
You might find it difficult keeping a ready supply of NPN spares.
Reply to 3 phase USA 3/60/220 to UK 3 phase is it doable thanks in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
