mattyevz
- Reaction score
- 2
Hi, iv been asked to change some lights in a wharehouse.I mostly experianced in the domestic side so bear with me .
The warehouse consists of 4 ailse, height of lights in each ailse is about 25ft . Width is about 7ft, length is about 30ft. At the moment they have got 3 x 8ft double flouresent fittings on each aisle hanging at about 25 ft up on chains from the roof.3 or 4 tubes on each light arnt working at the mo and the ones that are glow orange. They are obviously complaining about the poor lighting.
I was thinking about changing the tubes for new ones. But at 25ft up from the ground are they going to be that effective anyway with new tubes or would it be best to fit flood light type fittings with metal haloyd bulbs bolted to the steel gurders angled down?How many would you recomend on each aisle? Also the flouresents that are there at the moment have no metal cage covering to protect against damage as a folk lift is in use regular, would these need to be added ?. Any suggestions on what flood fittings would be best for a white light.
The only fixing points is the steel gurders. thanks peeps
