Discuss Bathroom light switch. in the UK Electrical Forum area at ElectriciansForums.net
Hi everybody. Newbie seeking advice. (Photo attached) I am trying to track down an online switch for a bathroom. The first switch on left is bathroom light. Middle switch fan. Right is 3amp fuse. Does anybody know what this switch is called? And, where I can buy one online (UK)? Thank you in advance.
It’s a grid switch set up with a fuse for the fan. To replicate your will need:
MK 3 Gang Grid
MK 3 Gang Faceplate
And the 3 inserts you need.
MK 3 Gang Grid
MK 3 Gang Faceplate
Thank you very much Chris!
[automerge]1600605617[/automerge]
That is the MEM Spectra range which is now obsolete although you can still pick them up. If matching like for like isn't a consideration most brands do similar ranges.
Thank you very much Westward!
Reply to Bathroom light switch. in the UK Electrical Forum area at ElectriciansForums.net
Hi, Just looking for some advice. In a bedroom there are 5 downlights on a dimmer switch. When turned on, every now and again these lights can...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
