• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
R
Roger Perkin
I am looking for an Electrician to advise on my first fit of lights and ring main for a garden office I am building.
Once I have all the wires run in and the ceilings and walls on I require them to connect up to Consumer Unit and then connect an armoured cable to the house.
Job is in SO45 1BG -
Calshot, Southampton
This is notifiable works and I would suspect any electrician would want to do the full works for the Electrical Installation Certificate.
The electrician will need to inspect all of the work you have done before it is covered. They will also need to see your design calculations for the cable sizes you have used.
Also you will have to sign the design and construction sections of the certificate as you are responsible for these parts of the work.
Garden Office - First Fit Advice and Electrician to connect up
Electrician Jobs
Electricians Jobs
Roger Perkin,
Octopus,
