under floor heating won't work in an old church for obvious reasons, a ridiculous suggestion, unless the parish church are prepared to install a modern floor on an old 200-500 year old concrete slab floor it just won't happen, and anycase listed building control would fight to the death in most cases to stop a floor going in, we are talking about a church 200 years old here not a modern bathroom :earmuffs:
I would have thought suggesting underfloor heating in a church would be a good thing. It'd focus the congregation on their devotion when the old giffer up front started banging on about eternal hellfire someone could whack up the stat.
Interactive sermons :-)
I fitted some ceramic radiant heaters into an old church room a while back, they don't glow red like the quartz ones, which some poeple don't like. I got them from heatstore, if you go to there website there is a calculator to help you design the best heating for the room. I found you need so many convector heaters for effective heating that radiants were the only real option. But they are hard to control and onlybheat what they hit. Your going to have to settle for a best worst case I think. Best of luck.
Is this them....?
3.0kW Ceramic Heater
Yep quite a few options.... I'll keep looking, price it all up tomorrow and see what works out the best
Reckon the Vac Air may be a bit out of their price range though :nopity:
You really need to be heating the objects with infrared heat and not wasting energy heating the air with blown air heaters.
below is a quote taken from Quote taken from - http://www.ehow.com/about_5348342_infrared-versus-quartz-ceramic-heaters.html
Infrared space heaters for the home emit long-wave infrared radiation, which strikes a solid nearby object and converts that radiation into heat. Infrared is not absorbed by the air through which it travels. With infrared heating, the warmth is directed and concentrated where it is really needed, so infrared heaters are better at targeted or focused heating. Infrared heaters are energy efficient, have no moving parts, heat very quickly, are silent, and are unaffected by drafts.
If you are sitting in one spot for a length of time, an infrared heater aimed in your direction will be a good choice.
ok so no reply as usual
i installed heating in a very old church uesing tubular heaters screwed under the pews with a wire guard on them all in micc
each line of pews had a 4 gang key switch and neon indicator fixed to the side of the pew at the isle
the oak seat heated up
Give us a chance.... Busy trying to watch rubbish TV here with the Mrs sythai
Anyway wooden pews, but not permently fixed
Thankyou for option anyway.
Cermaic/ radiant heating is looking favourable now as I also just remembered they don't want it to be noisy. So that blows my first idea out the water of the Dimplex commercial fan convectors
Whatever electric heating method this church chooses (and for me IR would be my choice) i hope they have deep pockets to be able to actually use these heaters!! Cause it ain't gonna be cheap, to run them!! Let alone the initial cost of the heaters and having them installed!! lol!!
The only time i step into a church is for Baptisms, Weddings and Funerals!! lol!!
