Discuss Led spotlights/downlights - how many please help in the UK Electrical Forum area at ElectriciansForums.net
Y
yipee458
Hi, I'm wanting to have some downlights fitted with gu10 LED bulbs 4w equivalent to 50w. The ceiling measures 5.92m by 3.57m. Can anyone advise how many would be suitable for this room size and how best to space them. Thanks
another quick thing, might aswell keep on one topic. i want to get a remote dimmer switch, does anyone know of any usable with led bulbs. thanx
Post 6 bang on pardon the pun! Joist permitting or if you're really unlucky RSJ permitting I use a unsheathed screwdriver have a precheck
You work to 150 aswell? I normally mark the lights out with a laser and then pop little pilot holes around it roughly the downlight size
I was referring to be governed by the joists I.e measuring the d/l all out so they would look neat as then what would you know a bit of wood is in my way
What room is? Because if its the kitchen the cupboard will throw out all of those calculations. Its not good having a down light directly above a cupboard. And then there's the joist spacing etc, I hate spacing down lights, actually, I hate down lights!
What about a lovely pendant, with a nice shade?
No, seriously, 150 what?
Presumably, from context, 150 cm.
Yipee458 selecting a dimmer switch is dependent on the lamps you have the lamps must be suitable for dimming and will normally specify if you need a leading edge or trailing edge dimmer. Whichever type you need they must be low load dimmers capable of running at a low wattage normally 0-100W or so.
Standard dimmer switches may work for a while but will eventually damage the lamps as the output is not suitable for LEDs.
BTW a 4W LED lamp will only be likely equivalent to 35W. Keep an eye on the beam angle as well.
I've just ordered some of these as my demo samples:
Ledlite LED Downlights IP66 Fire Rated
You can change your mind about beam angle after they're installed, which is nice.
And here's a pic of a job where the electrician didn't talk to the customer about the kitchen layout (not mine):
Thread #16
i know of a case similar to this but it turned out that the customer decided to have extra units fitted without telling the spark
Personally when fitting spots, I work out where the joists are then mark on the ceiling where the lights are going to be and ensure they look right, in a kitchen I would go approx 1m apart, in a lounge stretch it to about 1.5m apart.
Draw the room out on a piece of paper and mark the lights on, it usually gives a good idea, or if a kitchen draw on the plans
What a fail. Have to leave em like it and call them angled wall washers instead simples!
I doubt that they would meet the usual 0.5m separation from nearby surfaces instructions!
If they did, put adjustable down lights in to provide "an indirect lighting experience without overpowering the user with reflective light"!
Planned and played for obviously:speechless:
Reply to Led spotlights/downlights - how many please help in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi, Can anyone please advise on what LED recessed lights to buy and how to wire for media wall đź‘Ť
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
