Or maybe having a small shelf just inside the garage with a torch on....
Seriously tho, I think there may be existing faults if the MCB's/RCD's are going out so often that it is a concern.
I don't know, it's difficult to tell just how often these MCBs are tripping. On the one hand it's apparently being caused by 'routine' things such as bulbs blowing, although it's happening often enough to be a problem.
I can't help thinking this is just an excuse to dive in and change the CU.
I think it has been clearly shown already that this proposed CU repositioning is going to be a totally uneconomical folly to attempt for little to no gain!!
Why would you be groping around in the dark in the garage area, surely the lights in the garage would be on a dedicated circuit?? (or should or could be made to be) Even if it needs the addition of another switch next to the new door (2 way switch) that's nothing to sort out now is it??... lol!!!
Guess it all hinges on how much it would cost to install a new fire door in the garage then and the impact with regard to house insurance - it was just an idea :toilet:
Installing a domestic rated fire door, will be many times cheaper than a complete CU repositioning exercise such as you have described, in both time and money!!
Many houses have fire doors between the house and integral garage. I can't see it actually having any affect on the insurance as the garage is still integral.
The consensus is that moving the CU with all it entails will be far more expensive than putting in a door with a battery or emergency light to negotiate the garage.
Said all I can. Good luck
I'm out...
if you put a door in its going to cost and when building regs get involved cost even more with additional things so it complys,
cheapest option would be to extend lighting circuits into the house in a small CU.
The cheapest option would be to do nothing at all and continue with the present arrangement.
Moving the CU seems like a 'sticking plaster' solution - you might not have to go outside to reset a breaker, but you'd still have to go outside to get in the garage for any other reason, such as getting your glasses out of the car.
if you put a door in its going to cost and when building regs get involved cost even more with additional things so it complies,
Are you actually being serious here???
Reactions: 1 person
Adding a door to an external, load-bearing wall can be an expensive business. My mate (who's an architect) did it a few years ago to give access from his flat to the 'garden' outside; instead of wedding presents they asked for money for their door instead, which was going to cost over a grand - it's not just a case of bashing a hole in the wall, you need to get a structural engineer in so the house doesn't fall down.
They moved out a year or so later to move to a 'family home' but the garden door added more to the value of the property than they spent on it.
As I said on a recent thread the cheapest option isn't always the best, but I think in this situation a door straight through to the garage would be the best option, although I haven't seen the property myself.
Easiest option is for the homeowner to stop being soft and let his wife go out in the dark to the garage lol.
I mean what does she do from November to Feb when theres less than 9 hours daylight each day ? stay in curtain twitching ? lol.
Reactions: 2 people
Midwest
Supporter
Oxfordshire
Retired Electrician
Repositioning CU
Thread Tags
Tags Tags
None
Midwest,
Adam W,
