Discuss Some professional advice please in the UK Electrical Forum area at ElectriciansForums.net
I have built a bar at the top of my garden in it there is 4 sockets and 2 lights running off the one switch I have done it as a radial circuit I was going to get my mains cable into the house to my main board on its own braker and was going to put a 2 way consumer unit for my lights and sockets but was told I don't need one someone mentioned a switch box just to have my mains cable,socket cable and light cable coming from it with an on off switch as it's will be protected from the many rcd board in my house if someone could help me that would be great and maybe send me a link of what I need to buy for in the shed to connect my 3 main cables to there will be a fridge and a tv up there thanks
I'm a plaster by trade I thought this was a forum for help I have done the work of running all the cables putting my sockets on and lights all I need is a bit of advice ain't going to pay some electrician £100 - £200 to come and tell me which one of the 2 things I need to purchase thanks for your help
Are you going to be testing your installation as may as well get an electrician to do it if not as will need testing after
It's a forum for sparks to help each other.
I've got a room that needs plastering, I have got all the bits and done the prep - would you plaster it for me FOC?
Your a band aid?? Is that like a roadie?
A lot to be honest I plastered dug Ellis loft conversion when we had the heat wave 3 years ago 100 mm of king span in the rafters and 50 mm on top of joists with 15mm sound fire line board over the top tops of 3 story houses all I was after was abit of advice don't want to get into an argument we all graft and all need one another to make a house I have posted in the diy forum first time on here didn't know where to post
Reply to Some professional advice please in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
R
Hi. Can somebody please advice what to do next or should I do anything next or just leave that cable as it is? Just bought the house and found a...
Resident
R
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
