M
Mike Irving
Hi.....I think I'm being dumb.....when installing 35mm swa cable and then recording it on the schedule of test results sheet ....what conductor size do I log for live and cpc.....thanks in advance...
I've used the swa Earth to the DB and then attached a 2.5mm lead to the cpc board...
If the only earth for whatever is being supplied is via this 2.5mm lead, then I doubt it is going to be sufficient.
It could be a very long cable run fused down to 20 amps . but i am also doubtful :dizzy2:
