A
Andy78
Hang on a minute - this isn't a proper argument; you're just contradicting everything I say! (C) Monty Python.
Yes it is.
Nice to see pedantry being demonstrated at it's finest! I think the difference is purely semantic, but as a rule 'Consumer Unit' is language is use with domestic customers, other than that it's Distribution Board.
The regulations make a distinction between the two along with all manufacturers. I think it's a bit more than just semantics.
The original 'consumer unit' was specific to domestic single phase installations and incorporated the cutout, metering, main switch and circuit protective devices into a single unit. This was in the 1950s.
What I can't find is a more up to date definition, other than the one in bs7671 which is not overly specific
View attachment 29126View attachment 29127
I ...
IMO it seems like all CUs are DBs, but not all DBs are CUs...
That's what I said earlier, and is in the definition in bs7671, CUs are a particular type of DB which has passed specific type testing and has a DP main switch and a few other things
then what you are refering to is a mainboard or switchgear [emoji12]That's what I said earlier, and is in the definition in bs7671, CUs are a particular type of DB which has passed specific type testing and has a DP main switch and a few other things
here you go, acti9 wall mounted switchgearNope, switchgear has it's own definition and would normally encompass DBs, switch fuses, fused switches, busbar chambers etc etc.
Mainboard is not a defined term as far as I know, and not one that I think I have ever heard of before.
that is the biggest problem with Schneider gear.M2 is a CEF off shoot.
I personally prefer Hager.
I was in a house last week with a older Hager unit installed. I was able to easily fit the new Hager MCB's I have in the van to the 20 year old consumer unit
This is why I prefer Hager, they tend to make their gear backwards compatible, it is also a decent quality.
there are more than one type of isobar just to add to the confusion and the breakers look different (they still fit)Schneider gear is backwards compatible, they still produce both isobar and kwickline ramges
Would that be Acti9?there are more than one type of isobar just to add to the confusion and the breakers look different (they still fit)
then there is easy9 and another series as well but i cant remember the name
nope, there is another one as well as easy9, acti9 etcWould that be Acti9?
thats the one.Resi9?
They are on isobar4 now but they are all backwards compatible as far as I know, which is also the same as the previous (v good) MK sentry range as they were rebadged MG breakers.
Remember the board will only have a main switch in it no circuit breakers so there will be a lot of blanks to cover up..I'm going to order the Hager unit myself for the electrician since it seems he's getting ripped off or he is charging more for this M2. just to confirm that these rcbo's are the right ones for domestic. These will be replacing two light circuits fuses, 6A B, two finals 32 B and cooker on 32A B
Unit is Hag114 VML114
Rcbo's Hag ADN106, ADN132
Gil-lec is best for prices on all these
I may have been mistaken then, but I'm sure they are backwards compatible.
They are also still making the c60 and c120 MCBs
