Ansell Orbio - I think there is an IP65 adjustable in brass. Can't say on quality, just googled it for you :)
Don't get too excited, the adjustment isn't huge and appears to be done by a lens change. I think you may struggle because of the IP65 rating
Reactions: Rpa07
Yeah i just saw that there will it not just work the same though ? Its for a porch with a slanted roof they dont want the light shining directlyon the door
Loads of brass tilt lights out there, but not ip65.
I know ksr do an ip65 10W tilt light, but don't think they do it in brass.
Does it need an ip rating as high as that ?
What ip rating would you suggest for porch lights because of the slope of the porch theres no chance of any rain getting to them, i usually just use ip65 lights for all my porch/soffit lights
As per Andy, do you really need an IP65 fitting if it's under a porch roof.
You get shallow beam-angle MR16 and GU10 lamps which are 24/25 degrees instead of the usual 36 or 40 degrees. Maybe that might work for you.
If there's no roof leaks and they're not going to get direct rain or mist/spray then I don't see why a particular IP rating would be required.
IP33 is the minimum for an outdoor light but these are not really outdoors.
I have some IP44 eyball downlights (MR16 in PC) that I bought for a customer who then changed their mind. The manufacturer is not given but the downlight was called coniston. These where bought about 6 years ago though. I thought they were available in brass as well.
Brass ip65 adjustable downlight
Lighting Forum
JM ELECTRICAL,
Stufin135,
