G
Gigsy
Hi,
I am training to become and electrician, I have passed my C&G level 2 exams. I am working as an electrical improver.
I came across a consumer unit today, which has two main switches and two phases L2 and L3 supplying it.
Does this board comply with regs?
Can you take 2 phases to a consumer unit?
Is it rated for 400V and 25kA?
It is just a consumer unit. A metal box cant be rated for 400v.
The switches are rated correctly for the voltage and current they are being used for.
There is a 400v warning sticker on it.
The cable dressing police will be along in a moment to comment on the untidy cables....
  • Funny
Reactions: JK-Electrical
An enclosure and assembly absolutely can be rated for 400V or not as the case may be.
Ok well I am thinking why are there three neutrals on the first block on the right does this mean the neutral will be switched off with the first main switch, it is a bit hard to follow where the three neutrals go.
Also I notice that 6kA rated devices have been used.
Reactions: Vortigern
that is not what I call coacher ,wrong board their boy .
Dual tariff board?
T
There is nothing on the metal box which identifies it as being rated for anything, The switches are rated for 400v. But they are only subject to 230v each?
It is a normal domestic consumer unit?
T
Incoming neutral goes to 1st neutral bar.
Then linked from there to each switch
Gigsy,
Bobster,
