N
netblindpaul
Murdoch, the only one of those that you don't have free access to is GN5.And how many of us have , or have ready access to all of these ?
Are you going to ignore ‘manufacturers instructions’? And are you going to let us all know what ‘SWA glands’ are produced for if not to go on SWA cable?Are you EVER going to quote a BS 7671 reg that states clearly that SWA must be earthed at the supply end ?
Does it?ditto. Being a member of the IET and registered with the engineering council has its perks.
So where does it say in the regs you run can export the DNO earth?!It is a requirement of ESQCR (Reg 24 I believe) for the DNO to provide consumers a connection point to either the network neutral or protective conductor, for connection of the installation earth.
Regulation 25 allows the DNO to refuse this connection only if the installation fails to comply with BS7671, or could pose a danger or cause an interruption of supply.
What’s your membership number?Does it?
Can’t say I’ve really noticed.
SWA is an extraneous conductive part......go back to college.
134.1.1
