Depending on the size and placement of holes,a clued up BC inspector,may well not require you to do anything.
Those advocating the bolting of plates,need to know more about the dynamics,of how a beam functions. You may make things worse,by drilling yet more holes,for bolts...
Beam me up, Scottie.
That's by far the most sensible advice yet given. It's just a few bloody holes for goodness sake. How the hell can a flat roof be properly load bearing, is someone going to put an outdoor Jacuzzi on it? You could have had the job done by now.....
If you are going to do job properly the do it properly, no bodges allowed.
Maybe your customers should check on the amount of expanding foam and grip fill that you use ;o))))))
  • Funny
Reactions: telectrix
You've never go to bed at night, without brushing your teeth? :D
Did I say I had done similar? I would have done the job properly in the first place, but if some fella without a "Part P" qually (joke) has gone and dared to drill a wee hole out of place, I would't fanny about with wooden pegs and sister rafters, complete waste of time. Have you seen the holes your average plumber puts through? never heard of a house falling down because of a few holes here and there, more PC BC non-sense.
Its all about liability, "if" something happens in the future then guaranteed someone somewhere will try to weasel there way out of paying for it or being screwed over for their decisions in allowing it.
Its like the 18th ed, most of its cack but you lot will adhere to it as it Electrical God's bible and if you don't you can and will be sued.
This forum is full of people getting their knickers in a knot over being sued, setting houses on fire, being put in prison, electrocuting others and who know's what else for committing all sorts of minor misdemeanours, including this one. How many have you ever known get sued/prosecuted/imprisoned or anything else for such? It's plain common sense, a few miss-positioned holes in a non-load bearing component like a flat roof rafter or even a joist are not going to make a jot of difference and are completely wasting your time, or even make it worse, to try. Just stick the boards up and crack on!
Did you do the cladding on the Grenfell Tower BTW?
Rules and regs...all very well.
Commonsense...but that requires some idea of what is required for safety.
I don't care about splitting hairs, just putting a good job together...
However, putting a hole through a joist in the "wrong" place isn't a problem...if you realise what kind of joist you are tackling.
Honestly, common sense wins...if you have a brain.
Fixing a miss-drilled beam
SteveBz,
Intoelectrics,
